Mijn twijfel is ook wel weg.
Binnenkort maar even bestellen dat ding
You're probably surprised with the 70-300mm VR. If you don't need f/2.8, then you don't need the 70-200mm. Indeed, you'll like the 70-300mm at f/5.6 or f/8 better on an FX body. Close your mouth, that dropped jar makes you look stupid. Really. The 70-300mm has very good edge to edge performance and doesn't really start to fall down in any way until you start to approach 300mm. And even then, it'll do in a pinch.
