Rottemeren op een mooie dag in December
Ruud_388
Bericht door Ruud_388 » zo dec 09 2007 9:14 pm
Vorige week even erop uit met de D80
Hier het resultaat, graag jullie commentaar, op- en aanmerkingen.
En vooral..........wat kan beter en waar moet ik op letten?
<a href="http://www.flickr.com/photos/12614588@N03/2098775000/" title="DSC_3588 by Ruud_388, on Flickr"><img src="http://farm3.static.flickr.com/2395/2098775000_b39fb336c0_o.jpg" width="800" height="535" alt="DSC_3588"></a>
<a href="http://www.flickr.com/photos/12614588@N03/2098775090/" title="DSC_3595 by Ruud_388, on Flickr"><img src="http://farm3.static.flickr.com/2370/2098775090_2dcbd49bc0_o.jpg" width="800" height="420" alt="DSC_3595"></a>
<a href="http://www.flickr.com/photos/12614588@N03/2098775340/" title="DSC_3602 by Ruud_388, on Flickr"><img src="http://farm3.static.flickr.com/2058/2098775340_544531f4f3_o.jpg" width="800" height="535" alt="DSC_3602"></a>
<a href="http://www.flickr.com/photos/12614588@N03/2098775448/" title="DSC_3603 by Ruud_388, on Flickr"><img src="http://farm3.static.flickr.com/2073/2098775448_70e1a0ab29_o.jpg" width="800" height="535" alt="DSC_3603"></a>
<a href="http://www.flickr.com/photos/12614588@N03/2098775540/" title="DSC_3605 by Ruud_388, on Flickr"><img src="http://farm3.static.flickr.com/2103/2098775540_267616c238_o.jpg" width="800" height="535" alt="DSC_3605"></a>
<a href="http://www.flickr.com/photos/12614588@N03/2097997135/" title="DSC_3610 by Ruud_388, on Flickr"><img src="http://farm3.static.flickr.com/2145/2097997135_290d8561d8_o.jpg" width="800" height="656" alt="DSC_3610"></a>
<a href="http://www.flickr.com/photos/12614588@N03/2098775908/" title="DSC_3614 by Ruud_388, on Flickr"><img src="http://farm3.static.flickr.com/2068/2098775908_ee8a15387a_o.jpg" width="535" height="800" alt="DSC_3614"></a>
Ruud
Gr,
Ruud
Bericht door ALE » zo dec 09 2007 9:53 pm
Hoi Ruud,
Laat ik beginnen met de beste stuurlui staan aan de wal. De opmerkingen die ik hieronder geef beschouw die niet als negatief, maar probeer er je voordeel uit te halen. Ik ben ook nog nooit ter plekke geweest dus misschien zijn bepaalde tips überhaupt niet mogelijk. Ik heb dus absoluut niet de wijsheid in pacht laat dat duidelijk zijn.
Foto 1:
Een stapje naar achter en naar rechts. Dan had je de molen er ook in zijn geheel op gehad. Daarnaast begrijp ik niet hoe het mogelijk is dat de horizon recht staat (zie punt vanaf de molen naar de linker oever en vergelijk dat eens met het water rechts onder in de foto... Daar staat het water weer een heel stuk hoger.
Dan had ik de foto ook op ISO 200 genomen met een sluitertijd van 1/60e. Had je hetzelfde effect gekregen echter minder ruis in je wolken partij. Qua kleur en belichting perfect
Foto 2:
Hier had ik de sluitersnelheid met 2 stappen naar beneden gedraaid waardoor je je diafragma weer omhoog kunt krikken om zodoende meer scherpte diepte te krijgen.
foto 3:
Ook hier een stap naar rechts en de molen was precies tussen de begroeiing door vrij komen te staan. Lucht is iets uitgebeten, probeer eens hier je EV waarde met 2/3 (-0.7) te verlagen. Dan kun je daarna met je nabewerking programma het zaakje weer iets oplichten.
Foto 5:
De aanleg steiger had voor mij best in het midden van de foto gemogen. Had je een leuke diepgang gekregen en je werd als het ware de foto ingezogen. De rechter oever er vanaf snijden zodat er aan beide zijde water overblijft, voila. Pas op met de belichting (rechts bovenin je foto)
Foto 6:
Alleen die linker steel wegshoppen en voor de rest niets meer aan doen
Foto 6:
Achtergrond is te rommelig waardoor het niet lekker kijkt
Resumé: een dikke voldoende voor al je foto's, blijven oefenen en vooral posten.
Just my €0,02,
Laatst gewijzigd door ALE op ma dec 10 2007 10:31 pm, 1 keer totaal gewijzigd.
Marco
Bericht door Marco » zo dec 09 2007 10:07 pm
ALE schreef: Foto 1:
Hallo Ruud (en Arthur),
Lijkt mij vervorming op 18mm, even rechttrekken.....
Ik kom dit met mijn 18-70 ook wel eens tegen op 18mm.
groet,
Marco
Ruud_388
Bericht door Ruud_388 » ma dec 10 2007 8:18 pm
Hey Ale,
Bedankt voor je opmerkingen, hier kan ik iets mee.
Dit is de reden waarom ik mijn foto's post, ik zie het zeker niet als negatief.
Wat betrefd je opmerking over het water in foto 1 denk ik inderdaad dat het een tekortkoming van de 18-135 kitlens is. Of misschien heeft het iets te maken met een bocht in de rivier die er op dat punt is.
gr,
Ruud
Gr,
Ruud
