Aantal sluiterbewegingen d2x
Ruud van Es
Ruud van Es
Via Exif viewer krijg ik dit te zien:
File name: stoel04.JPG
File size: 4737567 bytes (4288x2848, 3.1bpp, 8x)
EXIF Summary: 1/320s f/9.0 ISO250 110mm (35mm eq:165mm)
Camera-Specific Properties:
Equipment Make: NIKON CORPORATION
Camera Model: NIKON D2X
Camera Software: PictureProject 1.6 M
Maximum Lens Aperture: f/2.8
Sensing Method: One-Chip Color Area
Color Filter Array Pattern: 830
Focal Length (35mm Equiv): 165 mm
Image-Specific Properties:
Image Orientation: Top, Left-Hand
Horizontal Resolution: 300 dpi
Vertical Resolution: 300 dpi
Image Created: 2008:04:29 22:27:39
Exposure Time: 1/320 sec
F-Number: f/9.0
Exposure Program: Normal Program
ISO Speed Rating: 250
Exposure Bias: 0 EV
Metering Mode: Pattern
Light Source: Unknown
Flash: No Flash
Focal Length: 110.00 mm
Comment: ENGELSE LIMOUSINE SERVICE VOORHOUT
Color Space Information: Uncalibrated
Image Width: 4288
Image Height: 2848
Rendering: Normal
Exposure Mode: Auto
Scene Capture Type: Standard
Gain Control: None
Contrast: Normal
Sharpness: Normal
Subject Distance Range: Unknown
ISO Speed Used: 250
Color Mode: COLOR
Image Quality: FINE
White Balance: AUTO
Image Sharpening: AUTO
Focus Mode: AF-C
ISO Speed Requested: 250
AE Bracket Compensation: 0.0 EV
Tone Compensation: AUTO
Lens Type: Nikon G Series
Lens Range: 70.0 - 200.0 mm; f/2.8
Auto Focus: Dynamic Area, Center Selected, Top Focused
Shooting/Bracketing Mode: Single Frame/Off
Color Mode: MODE1
Lighting Type: NATURAL
Noise Reduction: OFF
Camera Actuations: 11634
Saturation 2: NORMAL
Other Properties:
Resolution Unit: i
Chrominance Comp Positioning: Centered
Exif IFD Pointer: 232
Compression Scheme: JPEG Compression (Thumbnail)
Resolution Unit: i
Offset to JPEG SOI: 2570
Bytes of JPEG Data: 2062
Exif Version: 2.21
Image Generated: 2008:04:27 12:26:32
Image Digitized: 2008:04:27 12:26:32
Meaning of Each Comp: Unknown
DateTime Second Fraction: 65
DateTimeOriginal Second Fraction: 65
DateTimeDigitized Second Fraction: 65
File Source: Other
Scene Type: Unknown
White Balance: Auto
Digital Zoom Ratio: 1
Saturation: Normal
GPS Info Version: 2.2.0.0
Nikon Note Version: 2.10
Flash Used: No
F-Number: f/9.0
Exposure Bias: 0 EV
Flash: No Flash
Image Width: 4288
Image Height: 2848
Rendering: Normal
Exposure Mode: Auto
Gain Control: None
Contrast: Normal
Sharpness: Normal
ISO Speed Used: 250
Color Mode: COLOR
Image Quality: FINE
White Balance: AUTO
Focus Mode: AF-C
Color Mode: MODE1
Other Properties:
Resolution Unit: i
Resolution Unit: i
Exif Version: 2.21
File Source: Other
Scene Type: Unknown
White Balance: Auto
Saturation: Normal
Flash Used: No
iJoost
Misschien heb je een andere versie van MacOS X? Ik heb hier gewoon 10.5.2...
Het begint met drie tabs inderdaad: Algemene info, Meer info en Trefwoorden. En als je dan Meer Info selecteert komen er afhankelijk van de soort afbeelding (JPEG, PNG, NEF, etc.) een aantal sub-tabbladen bij. Zoals je ziet in mijn voorbeelden.
iJoost
- Riemke
Voor de PC kun je ook preview extractor downloaden. Met dat gratis programma kun je de JPEG's uit je Raw bestanden filteren, maar je kunt ook de shuttercount bekijken
http://drchung.new21.net/previewextractor/
Light
