D800(E) en D810 tips en trucs
Re: D800(E) tips en trucs
Bericht van vandaag (12/7) op de site van Nikon over het optisch laagdoorlaatfilter:
https://nikoneurope-nl.custhelp.com/app ... a_id/57867
Update van de lijst met objectieven die door NIKON worden aanbevolen voor de D800(E):
Toegevoegd zijn: (bron: Nikon Rumors)
AF-S NIKKOR 18-35mm f/3.5-4.5G ED
AF-S NIKKOR 80-400mm f/4.5-5.6G ED VR
AF-S NIKKOR 800mm f/5.6E FL ED VR
Nikon:
With cameras like the D800E, which are suited to photography of visually complex subjects, maximizing lens resolution is vital. Though results will vary from lens to lens, the greatest contrast all the way to frame peripheries can generally be achieved at an aperture setting two to three stops down from maximum aperture. Some lenses that offer excellent resolution are listed below.
AF-S NIKKOR 14-24mm f/2.8G ED
AF-S NIKKOR 16-35mm f/4G ED VR
AF-S NIKKOR 24-70mm f/2.8G ED
AF-S NIKKOR 24-85mm f/3.5-4.5G ED VR
AF-S NIKKOR 24-120mm f/4G ED VR
AF-S NIKKOR 70-200mm f/2.8G ED VR II
AF-S NIKKOR 70-200mm f/4G ED VR
AF-S NIKKOR 200-400mm f/4G ED VR II
AF-S NIKKOR 24mm f/1.4G ED
AF-S NIKKOR 28mm f/1.8G
AF-S NIKKOR 35mm f/1.4G
AF-S NIKKOR 85mm f/1.4G
AF-S NIKKOR 85mm f/1.8G
AF-S NIKKOR 200mm f/2G ED VR II
AF-S NIKKOR 300mm f/2.8G ED VR II
AF-S NIKKOR 400mm f/2.8G ED VR
AF-S NIKKOR 500mm f/4G ED VR
AF-S NIKKOR 600mm f/4G ED VR
AF-S Micro NIKKOR 60mm f/2.8G ED
AF-S VR Micro-Nikkor 105mm f/2.8G IF-ED
PC-E NIKKOR 24mm f/3.5D ED
PC-E Micro NIKKOR 45mm f/2.8D ED
PC-E Micro NIKKOR 85mm f/2.8D
The D800E offers better resolution at aperture settings with which diffraction is not an issue. As the aperture setting has more influence on resolution with the D800E than with the D800, D800E users should always keep the possible effects of diffraction in mind.
bron:
http://nps.nikonimaging.com/technical_s ... ips/d800e/
Nikon:
bron:
- Freaky87
Interessant topic; Bedankt Marten voor al het werk!!
Mijn website: http://www.freakyphoto.be --- http://www.freakyparty.be
Ook van hieruit, een oprechte dank voor deze zeer interessante bijdrage.
Dank!
Mochten jullie nieuwe tips of trucs tegenkomen, plaats ze vooral.
Diafragmaregeling D800(E) bij filmen:
http://www.nikon-club-nederland.nl/foru ... 70&t=50153
- Arie Vigelius
Relatie brandpuntsafstand - sluitertijd. Stukje TS (de rest mag je natuurlijk ook lezen
http://forum.belgiumdigital.com/f9/d800 ... 63879.html" onclick="window.open(this.href);return false;
- Martin
- Regiocoördinator
Goede tip!
Is in dit zelfde draadje al eens genoemd door Marten, zie 24.04 2013
- Martin
- Regiocoördinator
Vergissing, was 20 .04.2013
- Arie Vigelius
O ja dat zie ik nu ook. [FLUSHED FACE]
- John'47
Nikon D810, Sony RX1R II.
- iefie
Kwam wel mastering the D800 tegen op pdf
Had wat gedownload en deze zat erbij
Praktijktest D800E:
http://nikonrumors.com/2013/09/13/guest ... test.aspx/
Ik heb nu ingesteld: sluitertijd = 1/(3x de brandpuntsafstand) .Marten schreef:tip: brandpuntsafhankelijke auto-iso.
In te stellen : Opnamemenu / Iso gevoeligheid instellen / Autom inst ISO-gevoeligheid : On, Langste sluitertijd: AUTO
Snel aan en uit zetten: door ISO knop plus secundaire instelschijf (vóór de ontspanknop.)
zie ook: pag 111 Gebruikshandleiding D800(E)
Dat bevalt mij uitstekend. Het aantal foto's met uitmuntende scherpte is daardoor nog verder toegenomen. Je ISO gaat natuurlijk wel verder omhoog, maar de D800(E) kan wat dat betreft wel wat aan.
