The D60 is a nice camera that will appeal to most entry level DSLR users. However, I'm going to suggest that there's another group who will like it more: FM2 afficionados. Am I crazy? No. With the right lenses, the D60 is the small, light digital FM that everyone wants, with one addition: a Katz Eye screen (you can use the focus confirmation indicator, but there's a bit of tolerance in it that a true FM user would want to get rid of. Because you can mount pretty much any Nikkor lens ever made on the D60 it makes for a nice manual focus camera. However, those lenses don't set exposure. No fear, I have the perfect lens kit for you:
* Voightlander 20mm f/3.5. Gives you the equivalent of 28mm in the old film days, and this manual focus lens will meter on the D60 due to the CPU chip Cosina adds to it.
* Nikkor 30mm f/1.8G. Nikon has now introduced the perfect "normal" lens for this camera. No DOF scale, though, so you might want to consider the Sigma 30mm f/1.4 instead.
* Voightlander 40mm f/2 or Voightlander 58mm f/1.8. Again, both manual focus lenses and chipped to support exposure. The latter is a good equivalent for the 85mm on film.
* If you need macro or more telephoto, the Tamron 90mm f/2.8 and the Voightlander 180mm f/4 could round out your kit.
It's remarkable how small and convenient the combination is (D60, Katz Eye, 20mm, 30mm, 58mm). FM users will find it the equivalent to, say, carrying an FM2n, a 28mm, 50mm, and 85mm lens. All these lenses are optically quite good.
Voigtländer COLOR SKOPAR 20mm F3.5 SL II Aspherical
Re: Voigtländer COLOR SKOPAR 20mm F3.5 SL II Aspherical
Thom Hogan heeft een nieuwe theorie: De D60 met een aantal Voigtländer cpu-primes is de ideale vervanger voor de ouder FM2 body (hij weet alleen niet hoe je Voigtländer schrijft...).
OnlineSkippy
Ik heb dat ook met interesse gelezen. De eerste keer dat Thom Hogan over Voigtländer schrijft. Laat ik nou net afgelopen zaterdag met een dergelijke lichtgewicht setup in Rotterdam hebben gefotografeerd; D70s DX + Voigtländer 20mm + NIkkor 35mm + Nikkor 180mm. Overigens vind ik 180mm op DX eigenlijk al te lang, een 135mm of 150mm zou beter zijn, voor mij althans. Ik heb Thom Hogan gisteravond over dit onderwerp een e-mail gestuurd om hem te enthousiasmeren om meer over Voigtländer e.d. te schrijven op zijn website.joepert schreef:Thom Hogan heeft een nieuwe theorie: De D60 met een aantal Voigtländer cpu-primes is de ideale vervanger voor de ouder FM2 body (hij weet alleen niet hoe je Voigtländer schrijft...).
Wat ik me nog afvroeg: hoe regel je het diafragma op deze gechipte objectieven? Via de body of via de ring? En als je het via de ring regelt, hoe weet die body dan welk diafragma je gebruikt? Anders heb je nog steeds geen effectieve lichtmeting.
OnlineSkippy
Bij de Nikon AF-cameras (analoog en digitaal) zet je het objectief op de body en draait het diafragma op het objectief op f22. Indien je niet doet krijgt je een Error op je camera. Vervolgens regel je het diafragma op de camera, werkt perfect.joepert schreef:Wat ik me nog afvroeg: hoe regel je het diafragma op deze gechipte objectieven? Via de body of via de ring? En als je het via de ring regelt, hoe weet die body dan welk diafragma je gebruikt? Anders heb je nog steeds geen effectieve lichtmeting.
Ik vermoed dat je bij de Nikon MF-camera's die objectieven zonder vorkje "aankunnen" het diafragma op het objectief kunt bedienen. Bij MF-camera's die alleen werken met objectieven met een vorkje (Nikkormat etc.) zal de lichtmeting met zo'n Voigtländer niet werken net zoals de lichtmeting van een objectief met vorkje zonder cpu op een digitale slr niet werkt.
Bij de consumer Nikon camera's (D60, D80, D90) kun je de Voigtländer lenzen bedienen zoals je schreef met de diafragmaring op de lens op de kleinste opening gezet en dan verder instellen met de bediening van het diafragma met het instelwiel op de camera. Een en ander met behoud van lichtmeting. (Het is een lens met CPU).
Op Pro-bodies zoals D300, D700, D3, D3x, D1 en D2-lijn, kun je (met persoonlijke instellingen) tevens de optie kiezen om het diafragma te regelen met de diafragmaring van het objectief zelf. Ook gewoon met lichtmeting. De koppeling van het diafragma als functie in de lichtmeting wordt dan overgegeven via de meeneemnok van lens en camera.
Oude Nikkor manuele lenzen van het PRE-AI tijdperk kun je meestal niet gebruiken op zowel de eenvoudige als pro-modellen Nikon bodies, omdat de diafragmaring net iets over de lens-flens uitsteekt, en dan tegen de flens van de camera aankomt, en/of tegen een lichtmeter meeneemnokje van de body (indien aanwezig).
Er zijn dan net weer een paar uitzonderingen zoals de D40, D40x en D60, omdat de flens van de bajonet van de camera net iets smaller is, en de uitstekende diafragmarand van de lens er dan netjes naast en erover valt. Tevens ook geen meeneemnokje wat in de weg zou kunnen zitten.
AI(s) lenzen (met meeneemrand over pakweg 1/3 van de diafragmaring) kunnen wel gebruikt worden, ongeacht of er nog wel of geen vorkje opzit. Op de consumer Nikon camera's (D60, D80, D90) alleen geen lichtmeting.
Zie: http://www.bythom.com/lensacronyms.htm
Dank Léon voor de uitgebreide toelichting.
Wat Thom Hogan dus ook bepleit, is een D60-body (waar je dus in feite alle nikon F-mount objectieven kunt opzetten) die de software (en hardware?) heeft die ook in o.a. de D300 zit om toch lichtmeting te hebben. Dan heb je een compacte en eenvoudige DSLR waarmee ook mensen die het eenvoudig willen houden prima mee uit de voeten kunnen. Ik kijk bijvoorbeeld naar mijn vader, die op zich best de overstap naar digitaal zou willen maken. Echter, om met zijn Ai-objectieven uit de voeten te kunnen, zou hij van een FM naar een D300 moeten overstappen en dat is voor hem gewoon veel te veel van het goede.
Nee, met de D60 is geen lichtmeting mogelijk van oude AI(s) Nikkor objectieven.joepert schreef:Dank Léon voor de uitgebreide toelichting.
(zoals ik in mijn vorige reactie schreef: Op de consumer Nikon camera's (D60, D80, D90) alleen geen lichtmeting. )
De D60 heeft geen diafragma lichtmeet meeneemnok. Maar met manuele instelling kun je wel elke sluitertijd diafragma-combinatie maken en de belichting gewoon gokken. Binnen 1 seconde het resultaat op de LCD met histogram en clipping knipper-hulptool controleren en van daaruit eventueel bijsturen voor een nieuwe opname. Zo heb ik het eerder met de D80 ook gedaan.
- ArendV
Klopt Léon, maar Joep (en Thom) bedoelen dat de ideale compacte DSLR een D60 zou zijn die dat wel heeft (en een ander matglas om beter handmatig te kunnen scherpstellen).
Groeten - Arend / flickr
Precies! Maar dat zal wel toekomstmuziek blijven aangezien mensen dan niet 'gedwongen' worden om nieuwe objectieven te kopen
Nou, met de CPU uitgeruste Voigtländer lensjes (de 20mm, 40mm, 58mm SL II serie) heb je nu dus al wel lichtmeting en daarmee dus de "ideale" compacte DSLR zonder verdere aanpassing. Nou ja, met dat matglaasje erbij.ArendV schreef:Klopt Léon, maar Joep (en Thom) bedoelen dat de ideale compacte DSLR een D60 zou zijn die dat wel heeft (en een ander matglas om beter handmatig te kunnen scherpstellen).
Dat is wat Thom Hogan propageert. Hoewel hij niet erg nauwkeurig is over lens-specs. (afgaande tenminste op de tekst die hier is aangehaald). Ik dacht niet dat Nikon een 30mm/1.8 lensje heeft (wellicht de nieuwe 35mm/1.8 bedoeld). Verder heeft de Voigtländer 180mm f/4 geen CPU (dus ook geen lichtmeting op de D60), nog afgezien of je zo'n lensje nog ergens kunt vinden, want die is niet meer in productie. (Mischien komt er in de toekomst een her-introductie als SL II lens, zijnde met CPU).
Joepert reageerde ook naar aanleiding van oude objectieven, waarbij dat lichtmeetverhaal niet opgaat en ook niet in een compact instap model DSLR van Nikon zal worden geïntroduceerd.
We begrijpen elkaar weer helemaal!
