Als je al de 1.3.3 versie hebt kun je sinds eergisteren al een update doen naar de nieuwste versie.
Ga naar je Capture NX 1.3
Ga naar Help
Klik op Capture NX bijwerken
Klik onderaan op Controleren op nieuwe updates
Deze versie kan alleen bijgewerkt worden al je 1.3.3 er al op hebt staan.
En zet je firewall uit.
Modifications enabled with Ver. 1.3.4:
* Support for the Service Pack 1 versions of 32-bit Windows Vista Home Basic/Home Premium/Business/Enterprise/Ultimate has been added.
* Support for the Service Pack 3 versions of Windows XP/Home Edition has been added.
* Support for optional Picture Controls has been added. A dedicated button for downloading optional Picture Controls using the Picture Control Utility has been added. When downloaded optional Picture Control files are installed, they are added to the Picture Controls available in the Picture Control palette opened fromBase Adjustments>CameraAdjustments>Picture Control in the Capture NX Edit List, as well as to the Stored Picture Controls in the Picture Control Utility.
* The names of the following colored gel filters, which can be used with the Speedlight SB-900, are added to the Flash submenu in the White Balance palette opened fromBase Adjustments>RAWAdjustments>White Balance in the Edit List.
o FL-G1/FL-G2: filter for fluorescent light
o TN-A1/TN-A2: filter for incandescent light
* A Colored Gel Filter item has been added to the Shooting Info area in the Camera Settings palette
* When a new white balance setting was applied with selection of Calculate Automatically from the New WB pulldown menu in the White Balance palette opened fromBase Adjustments>RAWAdjustments>White Balance in the Edit List, and Set Gray Point then selected from the Set Color Temperature/Set Gray Point pulldown menu, the values for the Red and Blue sliders remained at 1. This issue has been resolved.
* An issue that caused the white balance setting specified in step 1 with the operation described below to be displayed as the current white balance setting in the New WB pulldown menu has been resolved.
1. A new white balance setting was applied from the New WB pulldown menu in the White Balance palette opened from Base Adjustments>RAW Adjustments>White Balance in the Edit List, and the image then saved in NEF format,
2. The newly saved image was opened again and the white balance setting changed to Recorded Value, selected from the New WB pulldown menu, and the image again saved in NEF format,
3. The image opened again
* When RAW images captured with the D3 or D300 at sensitivity settings in the LO range were opened, they were completely black. This issue has been resolved.
* When RAW images captured at some preset manual white balance settings were opened, they were incorrectly displayed with lines or bands, or completely white. This issue has been resolved.
Update Capture NX naar 1.3.4
- Hans Braakhuis
- Jur
Re: Update Capture NX naar 1.3.4
Reeds eerder gemeld; zie hier http://www.nikon-club-nederland.nl/foru ... hp?t=11062Hans Braakhuis schreef:Als je al de 1.3.3 versie hebt kun je sinds eergisteren al een update doen naar de nieuwste versie.
Jur
Inderdaad. Graag verder in dat andere draadje!Jur schreef:Reeds eerder gemeld; zie hier http://www.nikon-club-nederland.nl/foru ... hp?t=11062
