ExifPro 1.08
remoss
ExifPro 1.08
Bericht door remoss » di jun 16 2009 1:49 pm
ExifPro heeft weer een update ondergaan: versie 1.08
http://www.exifpro.com/
NEW: Support for Sigma S14 raw photos (X3F).
NEW: Support for Panasonic raw photos (RW2).
NEW: Various speed improvements and tweaks, optimized thumbnail decoding for faster and more responsive redraws, multithreaded thumbnail decoding taking advantage of multicore CPUs.
NEW: Optional thumbnail image sharpening. Note: This is sharpening of thumbnail images only, and for display purposes only. It can be adjusted or disabled in Advanced Settings. It's enabled by default on multi-core machines.
NEW: Tagging and/or rating multiple images shows progress bar, and can be interrupted if so desired. Saving file info to multiple images sports progress bar too.
NEW: Open current image in Explorer window (context menu, or Alt+X).
NEW: Preview bar in a viewer window can display text labels. File names or date can be shown underneath thumbnail images.
NEW: Text labels in the main window have a choice of showing file name with extension.
NEW: Image rotation buttons are available directly in the preview pane too.
FIX: Stability fixes; deleting files while scanning was in progress could lead to crashes.
FIX: Changing tags and rating updates results of current filter, if any.
FIX: Portrait orientation in DNG photos is recognized now, and images automatically rotated for display.
FIX: Out of multiple embedded preview images in DNG files, the biggest one is used.
FIX: Decoder bug fix to avoid crashing on broken images.
FIX: Filtering by tags didn't react to changes (checking tags) in Windows XP (it only worked in Vista).
FIX: Next and Previous buttons in File Info dialog are properly grayed out at the start/end of image collection.
FIX: Resize tool handles images with invalid pixel dimensions better.
FIX: Updated color management library handles properly image highlights when used with Spyder monitor profiles.
FIX: Report broken ICC/ICM profiles when selecting them in color management dialog.
Updated ICM library is less forgiving when it comes to errors in color profiles, some of them may be rejected.
Faster reloading of images when using groupping by date.
Image adjustment dialog remembers last selected tab.
Dennis71
Re: ExifPro 1.08
Bericht door Dennis71 » di jun 16 2009 2:07 pm
Thx for the info.
Gebruik het altijd. Echt een waanzinnig programma.
remoss
Re: ExifPro 1.08
Bericht door remoss » di jun 16 2009 2:10 pm
Ik ken sowieso geen enkel andere fotobrowser die zo rap door NEF's struint :)
Dennis71
Re: ExifPro 1.08
Bericht door Dennis71 » di jun 16 2009 2:40 pm
Ik ook niet. Sinds jouw tip heb ik het programma in gebruik.
Frans Keijzers
Re: ExifPro 1.08
Bericht door Frans Keijzers » di jun 16 2009 5:01 pm
Werkt het programma ook op een imac?
Groet, Frans
Nikon D80 - Nikkor AF-S DX 18-70mm F/3.5-4.5 G IF - Nikkor 50mm AF F/1.8 D - Sigma 70-200mm F2.8 APO EX DG MACRO II HSM Nikon
http://www.franskeijzers.com
ArjanL
Re: ExifPro 1.08
Bericht door ArjanL » di jun 16 2009 7:54 pm
Frans, jij hebt Quick Look (Mac OS 10.5) Selecteer een bestand en druk op de spatiebalk. Geen programma voor nodig, tenzij je wilt bewerken. QL is sneller dan welk programma ook. Werkt ook voor jpg, mov, mp3, doc, ppt, pdf, etc, etc, etc.
Arend-ho
Re: ExifPro 1.08
Bericht door Arend-ho » di jun 16 2009 9:16 pm
mm ff update trekken.....tx
Arend
Frans Keijzers
Re: ExifPro 1.08
Bericht door Frans Keijzers » di jun 16 2009 10:23 pm
ArjanL schreef:Frans, jij hebt Quick Look (Mac OS 10.5) Selecteer een bestand en druk op de spatiebalk. Geen programma voor nodig, tenzij je wilt bewerken. QL is sneller dan welk programma ook. Werkt ook voor jpg, mov, mp3, doc, ppt, pdf, etc, etc, etc.
Bedankt voor de tip Arjan deze kende ik nog niet.
Groet, Frans
