Samyang timmert weer prima aan de weg met hun nieuwe "poor mans" 24mm f/1.4 ED AS UMC lens.
http://www.dpreview.com/news/1108/11081 ... ng24mm.asp" onclick="window.open(this.href);return false;
Met de eerder geïntroduceerde 35mm/1.4 die optisch gezien heel aardig overeind blijft staan naast de gevestigde topmerken van Canon, Zeiss en Nikon in dat segment, is deze lens opnieuw een welkome aanvulling voor de "poor mans" fotograaf die met minder te besteden budget dezelfde fotografische low light mogelijkheden wil verkennen.
Nieuwe Samyang 24mm f/1.4 lens
- a vgastel
Re: Nieuwe Samyang 24mm f/1.4 lens
Click here to find out more!
Home > Gear
Samyang/Rokinon Announce New 24mm F/1.4 Lens
Korean lensmakers Samyang/Rokinon have just announced a new, manual-focus 24mm lens, available in five different mounts.
By Tim Barribeau on August 12, 2011
Related Tags:
Gear,
Lenses,
prime,
rokinon,
Samyang,
wide angle
Enlarge
Korean lens manufacturer Samyang — often sold in the USA as Rokinon — has just announced the European release of a 24mm F/1.4 lens. Their lenses are well known for being remarkably affordable but eschewing all automatic focus for a more manual approach. Because they're manual, you'll see Rokinon lenses in all common formats, and this 24mm version will be released for Canon, Nikon, Sony Alpha, Pentax, Samsung NX and Four Thirds .
The optics are comprised of 13 lenses arranged in 12 groups, with 4 lenses has been made of the low-dispersion glass (ED), and two aspheric lenses.
Since this lens will fit on just about any mount on the planet, keep in mind your crop factors. On full frame, it's 24mm, on APS-C it's near 36mm equivalent, and with a Four Thirds mount that bumps up to almost 50mm equivalency.
If you're curious about how these lenses perform, check out our review of the 35mm F/1.4 version.
We don't have a firm price or street date for the lens yet. The press release says it'll hit stores late 2011 or early 2012, with official price to be announced later. Given that 35mm F/1.4 goes for $500, we assume that the 24mm will be similarly priced.
- BStollman
Deze lens heeft zeker mijn interesse. Eens wat dieper in duiken
http://www.flickr.com/photos/bramstollman/" onclick="window.open(this.href);return false;
http://www.twitter.com/BramStollman" onclick="window.open(this.href);return false;
- pveenstra
Manual focus en diafragmaring zonder vergrendeling, waarschijnlijk ook geen CPU, dus wordt dit wel heel erg basic?
Hartelijke groet,
Peter Veenstra
Peter Veenstra
Dat "waarschijnlijk ook geen CPU" is niet juist. Je kunt zelfs kiezen met of zonder CPU.
Hier een Samyang objectief 14mm met CPU
Het is ook maar wat je "heel erg basic" wenst te noemen...
Een 1,4/24mm met inwendige scherpstelling, multicoating, vier ED-elementen, twee a-sferische elementen in een prachtige mechanische kwaliteit en een naar verwachting optische kwaliteit die de "niet meer zo heel erg basic"-merken het vuur na aan de schenen legt... Basic? BASIC?
En zoals te zien is aan de contacten en zoals Léon aangeeft: hij is, net als de Zeiss-objectieven, met CPU te krijgen. (Alleen jammer dan Zeiss dan ook maar de diafragmaring weglaat, die Samyang keurig laat zitten...)
Diafragmaring hoeft niet vergrendeld te worden, trouwens.
Dat vergrendelen is maar een hulpmiddel, net als bijvoorbeeld piepjes...
Om maar eens te parafraseren:
"Who needs AF, CPU, aperture-locking and aperture-control from the body, anyway?"
Het is om te fotograferen hoor...
Nikon heeft misschien wel met opzet die vergrendeling erop gezet om gebruikers alvast te laten wennen aan het idee dat vroeg of laat ze die diafragmaring helemaal weg zouden laten. Het is een zodanig onhandig klein priegelknopje dat je het idee hebt dat het "hoort" dat de diafragmaring "vast zit" en die diafragmaring geen functie zou hebben.emdeklerk schreef: Diafragmaring hoeft niet vergrendeld te worden, trouwens.
Voor de werking van het lichtmeetsysteem bij de kleinste diafragmawaarde doet zo'n knopje helemaal niet ter zake, dus overbodig.
Bij Voigtlander objectieven met CPU zitten er ook geen vergrendelingen op. Nooit problemen mee gehad dat het er niet op zit.
