PTGui is recentelijk ook geupdate.
http://www.ptgui.com/download.html" onclick="window.open(this.href);return false;
Een hele waslijst aan wijzigingen:
Version 9.1.4 (25 October 2012)
◦dcraw updated to version 9.16
◦PTGui Pro now supports layered Photoshop output for 32 bit HDR projects. Useful for manual retouching or deghosting
◦Batch Builder can now be configured to include only images with certain file extensions
◦Option to show or hide the mask in the Control Points tab
◦PTGui optimizer now supports two different methods for handling horizontal line / vertical line control points. 'Level in second pass' first optimizes the panorama using the regular control points and then does a separate leveling step using the line-type control points. This is the method that was always used in previous versions. 'Include in single pass' will do a single optimization pass using all control points. This is the method used by the Panotools optimizer. See the Help page for the Optimizer tab for details.
◦Align to Grid now gives an error message if the resulting panorama would be wider than 360 degrees or taller than 180 degrees.
◦Default setting for the maximum number of control points to generate for a project has been increased from 2500 to 8000
◦PTGui Viewer now supports Firefox in CSS 3D mode too (in case WebGL is not available)
◦PTGui Viewer: Removed the Full Screen option from the right-click context menu in Flash mode, since this is no longer supported by Flash player. Full screen mode is still accessible through the full screen button at the top right of the displayed panorama, or by double clicking.
◦Running Align Images for a 360 degree panorama now attempts to preserve the center of the panorama if the images were already roughly aligned. Previously it would choose a random center point.
◦PTGui for Mac now requires OS X 10.5 or later. Only one version is distributed for Intel 32 and 64 bit support on all OS versions.
◦Support for full screen mode on Mac: click the arrows at the top right of the window (requires OS X 10.7 or later)
◦If one of the source images contains a GPS Image Direction EXIF tag, PTGui will include the Image Direction tag in the created panorama (TIFF/JPEG output only)
◦Added sensor size data for new cameras
◦Fix: using horizontal line control points for a rectilinear output image did not work properly (since the optimization was in fact done in equirectangular space regardless of the output projection)
◦Fix: for certain panoramas the optimizer would give up early, resulting in higher than necessary control point errors
◦Fix: optimizer would fail to optimize certain projects if the initial alignment of the images was too far off
◦Fix: for 360 degree panoramas, the optimizer would not always keep orphaned images together with the panorama. This caused problems when using Align to Grid with 360 degree panoramas.
◦Fix: raw files from the Canon 5D mk III would be loaded with a purple tint (fixed in dcraw 9.16)
◦Fix: certain DNG files would be loaded incorrectly, with black border and vertical stripes (fixed in dcraw 9.16)
◦Fix: tooltips for the Control point table window were missing
◦Fix: Convert to Cubic would give 'unsupported file type' error when generating .exr ouput
◦Fix: When outputting individual layers, a black rectangle could be visible to the right or bottom of the warped image
◦Fix: Align Images could change the panorama size by 1 or 2 pixels even if Align Images Behaviour was set to not change the panorama size
◦Fix: When previewing a spherical panorama in QuickTime using the 'eye' button in the Panorama Editor, the generated preview could be limited in tilt such that the nadir and zenith were not visible. This happened if the width of the panorama editor was odd and thus not exactly a 2:1 equirectangular.
◦Fix: Mac Help files were not visible in OS 10.5
◦Fix: Due to a bug, stitching certain non-360 degree gigapixel panoramas became slower in version 9.1.1. The speed is now improved again.
Update PTGui --> 9.1.4
CaptainHook
Re: Update PTGui --> 9.1.4
Ehhh, is al weer achterhaald:
http://www.nikon-club-nederland.nl/foru ... 17&t=44083" onclick="window.open(this.href);return false;
Frans Heinsbroek
Dat gaat hard: ik had de vorige update nog niet eens gedownload !
