Test Nikkor Fisheye 7,5mm f.5.6 uit 1967
Discussies over verzamelobjecten
Ed Post
Bericht door Ed Post » vr jan 10 2014 6:53 pm
Hieronder een test van de Nikkor Fisheye 7,5mm f.5.6 uit het blad Focus van juni 1967.
Afbeelding Afbeelding
Laatst gewijzigd door Ed Post op vr jan 10 2014 7:16 pm, 1 keer totaal gewijzigd.
emdeklerk
Re: Test Nikkor Fisheye 7,5mm f.5.6
Bericht door emdeklerk » vr jan 10 2014 7:08 pm
En wederom: dank!
Zijn er niet veel van gemaakt, van die 7,5mm...
Nu een heel mooit object voor een Westlicht-veiling!
a90
Re: Test Nikkor Fisheye 7,5mm f.5.6 uit 1967
Bericht door a90 » vr jan 10 2014 7:21 pm
Leuk stuk Ed, waarvoor dank.
Heb je misschien nog wat liggen van de Nikkor 13mm f/5.6 AIS ?
a vgastel
Bericht door a vgastel » vr jan 10 2014 7:35 pm
U vraagt
The 13mm f/5.6 Nikkor ultra-wide-angle lens was introduced in March 1976 in a pre-AI type lens mount. This extraordinary lens has only ever been available to special order. The 13mm f/5.6 covers an angle of 118º. It weighs in at 1200 grams and represents the widest rectilinear lens available for the 35mm format. It is 4 inches long (10.2cm), with an aperture range from f/5.6 to f/22.
It has 16 elements in 12 groups; the front element has a diameter of almost 11cm and is surrounded by a fixed ‘petal’ style lens hood. It has a floating rear element design, CRC close-range correction, a rectilinear element design for straight line rendition and can focus down to one foot. In 1977 the lens was updated to the AI standard, and in March 1982 the third version was introduced with the AIS type mount with four x 39mm (rear bayonet mount) filters: Skylight, Orange, Amber and Blue in a CL-14 case.
It was designed by Mr. Ikuo Mori of the 1st Optical Section, Optical Designing Department at Nikon Optical Japan. Apparently only about 350 of these lenses were ever made. “It is Nikon’s greatest lens because not only is it big and supremely expensive, it is Nikon’s, and perhaps photography’s, greatest lens because it lets us make photographs we can make no other way.” Ken Rockwell. MINT- £25,000
Ed Post
Bericht door Ed Post » vr jan 10 2014 7:49 pm
a90 schreef:Leuk stuk Ed, waarvoor dank.
Die kans is zeer aanwezig.
Echter, is ben momenteel nog in 1967 aan het spitten, en de AIS objectieven zijn van veel later.
Dus even geduld.
a90
Bericht door a90 » vr jan 10 2014 9:14 pm
Haha, die Ed ! Je moet nog door de stapels heen hoor ik al. Ik hou me van harte aanbevolen ook voor bv stukjes over de 105 4,5 UV-Nikkor of soortgelijke exoten. Ik weet dat er al veel op het net te vinden is maar nieuwe info is altijd leuk.
En Bert, alvast hartelijk dank !
Mcihael
Bericht door Vincent » vr jan 10 2014 9:38 pm
Maar bij de 7.5mm fisheye moet de spiegel dus vooraf opgeklapt worden omdat anders de achterkant van de lens voorkomt dat je deze kunt opklappen en daarom is er een hotshoe-zoeker meegeleverd met een kleinere beeldhoek om toch je compositie te kunnen zien...?
Mooi speelgoed :D
EdvandeZilver
Bericht door EdvandeZilver » vr jan 10 2014 9:46 pm
Klopt. Spiegel eerst opklappen.
Kijk naar het uitstulpende deel achter de bajonet.
http://www.destoutz.ch/lens_7.5mm_f5.6_750139.html
Terug naar “Fotografica”
