http://blogs.adobe.com/lightroomjournal ... ID=3006718" onclick="window.open(this.href);return false;
Een hoop wijzigingen, vooral in relatie met Nikon producten (!).
Te updaten via o.a. de ingebouwde update functies van Photoshop en/of Lightroom. Of zie de links onderaan dit artikel.
Camera Raw 8.5 and DNG Converter 8.5 now available
Camera Raw 8.5 is now available as a final release for Photoshop CS6 and Photoshop CC. This release provides new features including new preview controls, the ability to modify graduated and radial filters, and a new visualization mask for graduated and radial filters. In addition, this release also includes bug fixes, support for new cameras and new lenses. DNG Converter 8.5 is provided for customers using versions of Photoshop older than Photoshop CS6.
As mentioned here, updates to Camera Raw 8 for Photoshop CS6 only include new camera support, lens profile support, and bug fixes. The new features listed in the release notes are only available in Photoshop CC.
Release Notes
Features:
Modify Graduated and Radial Filter masks with a brush:
After adding or selecting a Graduated or Radial Filter instance, click the new ‘Brush’ mode (next to existing ‘New’ and ‘Edit’ mode buttons) to reveal brush controls that allow you to modify the selected mask.
Use the ‘Brush +’ and ‘Brush -’ icon buttons in the brush controls pane to add to or erase from the selected mask.
Press the ‘Clear’ button to remove all brush modifications from the currently selected mask.
When a Graduated or Radial Filter instance is selected, Shift-K can be used to enter and leave brush modification mode.
For more information, check out this video here
Mask visualization is now available for the Graduated and Radial Filters. Use the Mask checkbox at the bottom of the Local Corrections pane or press ‘Y’ to toggle the mask overlay.
Added Per-Panel Preview default toggle button
If the current panel’s settings are not the ACR defaults, clicking the new Per-panel Toggle Button will reset the panel to the ACR defaults.
Clicking the button again will restore the previous settings.
This is a standalone feature, separate from the new Preview controls.
The changes are applied to the main view; if you have both the Before and After panes visible, changes will appear in the After panel.
New Camera Support in Camera Raw 8.5
Canon PowerShot G1 X Mark II
Fujifilm FinePix S1
Nikon 1 J4
Nikon 1 S2
Nikon 1 V3
Olympus OM-D E-M10
Panasonic DMC-GH4
Pentax 645Z
Samsung NX3000
Sony DSC-RX100 III
Sony A7S (ILCE-7S)
Sony Alpha SLT-A77 II (ILCA-77M2)
New Lens Profile Support in Camera Raw 8.5
Mount Name
Canon Sigma 50m F1.4 DG HSM A014
Canon Sigma 18-200mm F3.5-6.3 DC MACRO OS HSM C014
Canon Tamron 16-300mm F3.5-6.3 Dill VC PZD MACRO B0163
Fujifilm Fujifilm Tele Conversion Lens TCL-X100
Nikon Nikon 1 NIKKOR VR 10-30mm f3.5-5.6 PD-ZOOM
Nikon Nikon AF-S DX NIKKOR 18-300mm f/3.5-6.3G ED VR
Nikon Sigma 50mm F1.4 DG HSM A014
Nikon Sigma 18-200 F3.5-6.3 DC MACRO OS HSM C014
Nikon Tamron 16-300mm F3.5-6.3 Dill VC PZD MACRO B016N
Nikon Tamron SP 150-600mm F5-6.3 Di VC USD A011N
Pentax Sigma 30mm F.14 DC HSM A013
Sigma Sigma 50mm F1.4 DG HSM A014
Sigma Sigma 18-200mm F3.5-6.3 DC MACRO OS HSM C014
Sony Alpha Sigma 30mm F1.4 DC HSM A013
Sony Alpha Sony Alpha 28-75mm F2.8 SAM
Bugs Corrected in Camera Raw 8.5
Fixed issue with Fujifilm X-T1 raw images appearing too bright at high ISO settings when using Dynamic Range 200% and 400%. Unfortunately, this fix may affect the appearance of existing images captured with this combination of settings. It is recommended that you (1) purge the Camera Raw cache via the Camera Raw Preferences dialog, and (2) review images shot at ISO settings higher than 1600 for unexpected brightness changes.
Fixed image quality issue (noisy result) when applying spot healing to floating-point (HDR) images.
Fixed issue with reading lossless compressed Nikon raw files (NEF files) from the camera models listed below. Previously, some images could be read but would appear as random noise, whereas attempting to open others would result in an error dialog. You will need to purge your Camera Raw cache via the Camera Raw Preferences dialog.
Nikon D1
Nikon D1H
Nikon D1X
Nikon D2H
Nikon D2Hs
Nikon D2X
Nikon D2Xs
Nikon D100
Nikon D200
Known Bug
Customers using the Sony RX100 M3 and capturing images at ISO 125 may find the default rendering in ACR and Lightroom too dark. This is a known issue and we are working to improve this in a future update.
Download Links:
DNG Converter 8.5:
Mac – http://www.adobe.com/support/downloads/ ... ftpID=5793" onclick="window.open(this.href);return false;
Windows – http://www.adobe.com/support/downloads/ ... ftpID=5794" onclick="window.open(this.href);return false;f
