Kerk Schinnen
erikcreugers
Kerk Schinnen
Bericht door erikcreugers » za mar 07 2015 3:40 pm
De Exif is niet meegestuurd... Dan maar even hier plakken:
JFIFVersion - 1.02
X-Resolution - 300 dpi
Y-Resolution - 300 dpi
Make - NIKON CORPORATION
Orientation - Horizontal (normal)
Software - Capture NX-D 1.0.3 W
Date and Time (Modified) - 2015:03:07 15:26:20
Artist - Erik Creugers
White Point - 0.313 0.329
Primary Chromaticities - 0.64 0.33 0.21 0.71 0.15 0.06
YCb Cr Coefficients - 0.299 0.587 0.114
YCbCr Positioning - Centered
Reference Black White - 0 255 0 255 0 255
Copyright - 2015 Erik Creugers Fotografie
ISO Speed - 400
Sensitivity Type - Recommended Exposure Index
Exif Version - 0230
Date and Time (Original) - 2015:03:07 14:45:46
Date and Time (Digitized) - 2015:03:07 14:45:46
Components Configuration - Y, Cb, Cr, -
Exposure Bias - 0 EV
Max Aperture Value - 1.7
Metering Mode - Multi-segment
Light Source - Fine Weather
Sub Sec Time - 90
Sub Sec Time Original - 90
Sub Sec Time Digitized - 90
Flashpix Version - 0100
Color Space - Uncalibrated
Sensing Method - One-chip color area
File Source - Digital Camera
Scene Type - Directly photographed
CFAPattern - [Red,Green][Green,Blue]
Custom Rendered - Normal
Exposure Mode - Manual
White Balance - Manual
Digital Zoom Ratio - 1
Focal Length (35mm format) - 50 mm
Scene Capture Type - Portrait
Gain Control - Low gain up
Contrast - Normal
Saturation - Normal
Sharpness - Normal
Subject Distance Range - Unknown
Gamma - 2.2
Maker Note Version - 2.11
Quality - RAW
White Balance - Sunny
Focus Mode - AF-S
White Balance Fine Tune - 0 0
WB_ RBLevels - 1.90625 1.390625 1 1
Program Shift - 0
Exposure Difference - -1.1
Exposure Bracket Value - 0
Crop Hi Speed - Off (6080x4028 cropped to 6080x4028 at pixel 0,0)
Exposure Tuning - 0
Serial Number - 6048507
Color Space - Adobe RGB
VRInfo Version - 0100
Vibration Reduction - Off
VRMode - Normal
Active D- Lighting - Off
Picture Control Version - 0100
Picture Control Name - Portrait
Picture Control Base - Portrait
Picture Control Adjust - Default Settings
Picture Control Quick Adjust - Normal
Sharpness - 2
Contrast - Normal
Brightness - Normal
Saturation - Normal
Hue Adjustment - None
Filter Effect - n/a
Toning Effect - n/a
Toning Saturation - n/a
Timezone - +01:00
Daylight Savings - Yes
Date Display Format - D/M/Y
ISOExpansion - Off
ISO2 - 400
ISOExpansion2 - Off
Vignette Control - Normal
Auto Distortion Control - On
Lens Type - G
Flash Mode - Did Not Fire
Shooting Mode - Single-Frame
Lens FStops - 6.33
Contrast Curve - (Binary data 578 bytes, use -b option to extract)
Shot Info Version - 0232
Firmware Version - 1.01
Noise Reduction - Off
Color Balance Version - 0220
Lens Data Version - 0204
Exit Pupil Position - 66.1 mm
AFAperture - 1.8
Focus Position - 0x03
Focus Distance - 6.31 m
Lens IDNumber - 176
Min Focal Length - 50.4 mm
Max Focal Length - 50.4 mm
Max Aperture At Min Focal - 1.8
Max Aperture At Max Focal - 1.8
MCUVersion - 178
Effective Max Aperture - 1.8
Raw Image Center - 3040 2014
Retouch History - None
Image Data Size - 16756787
Shutter Count - 456
Multi Exposure Version - 0100
Multi Exposure Mode - Off
Multi Exposure Shots - 0
Multi Exposure Auto Gain - Off
High ISONoise Reduction - Normal
Power Up Time - 0000:00:00 00:00:00
AFInfo2 Version - 0100
Contrast Detect AF - Off
AFArea Mode - Single Area
Phase Detect AF - On (39-point)
Primary AFPoint - C6 (Center)
AFPoints Used - C6
Contrast Detect AFIn Focus - No
File Info Version - 0100
Directory Number - 102
File Number - 5435
AFFine Tune - Off
AFFine Tune Index - n/a
AFFine Tune Adj - 0
Nikon Capture Version - Capture NX-D 1.0.3 W
IFD0_ Offset - 15248
Preview IFD_ Offset - 15148
NEFBit Depth - 14
Compression - JPEG (old-style)
XResolution - 300
YResolution - 300
Preview Image Start - 19366
Preview Image Length - 46125
Thumbnail Offset - 15372
Thumbnail Length - 3994
Camera ID - 72157636367648484
Camera Type - Digital SLR
Nikon D610 | Tamron SP AF 28-75 f/2.8 XR DI | Nikkor AF 85mm f/1.8D | Nikkor AF-S 50 mm f/1.8G | Nikkor 70-300mm f/4-5.6G| SB700
Website: http://www.erikcreugers.nl
reneo57
Re: Kerk Schinnen
Bericht door reneo57 » za mar 07 2015 4:04 pm
Mooie foto goede genomen, alleen wat weinig exif gegevens. :wink:
bcvthul
Re: Kerk Schinnen
Bericht door bcvthul » za mar 07 2015 4:45 pm
Ik zou wat dichterbij hebben gestaan (of wat meer ingezoomd) zodat de kerk wat beter in beeld komt. Nu is de voorgrond wat storend (vind ik). Zeker het gebouwtje linksvoor.
erikcreugers
Re: Kerk Schinnen
Bericht door erikcreugers » za mar 07 2015 5:26 pm
bcvthul schreef:Ik zou wat dichterbij hebben gestaan (of wat meer ingezoomd) zodat de kerk wat beter in beeld komt. Nu is de voorgrond wat storend (vind ik). Zeker het gebouwtje linksvoor.
Dichterbij gaan of inzoomen was beiden niet mogelijk helaas. Ik stond al bijna tegen het prikkeldraad, en ik heb een primelens gebruikt. Had de rugzak met de zoomlens wel bij me, maar gezien het feit dat het daar nog ontzettend modderig was, maar afgezien van een lenswissel...
Cookie1397
Re: Kerk Schinnen
Bericht door Cookie1397 » za mar 07 2015 5:57 pm
Andere uitsnede maken moet kunnen en persoonlijk zou ik de lucht iets donkerder maken
Terug naar “Landschappen”
