ExifTool --> 9.96
CaptainHook
ExifTool --> 9.96
Bericht door CaptainHook » ma jun 01 2015 7:06 pm
Heel recent is het bekende ExifTool by Phil Harvey ook geupdate naar versie 9.96
http://www.sno.phy.queensu.ca/~phil/exiftool/" onclick="window.open(this.href);return false;
May 20, 2015 - Version 9.96
•Added support for CanonVRD version 4 information and DR4 files
•Added two new Canon LensType values (thanks Norbert Wasser)
•Added two new Olympus LensType values (thanks Niels Kristian Bech Jensen)
•Added a new Minolta/Sony LensType and fixed another one (thanks Jos Roost)
•Added a new Nikon LensID (thanks John Helour)
•Added a few new QuickTime tags
•Added a new PentaxModelID and a new Pentax PictureMode
•Added a few new XMP-aux tags
•Decode a couple more DPX tags
•Decode NikonCustom tags for D810 firmware version 1.02
•Improved -htmlDump output for extended XMP and some other JPEG segments
•Improved a Canon lens name
•Documented the -userParam command-line option (which has existed since 9.90)
•Changed default behaviour to ignore extended XMP with an incorrect GUID (as per the XMP specification)
•Changed the case of a few tag names for consistency
•Patched problem with Sony cameras giving incorrect LensInfo for some third party lenses, leading to an incorrect LensID by ExifTool (thanks Jos Roost)
•Patched problem where GPS minutes or seconds could round up to 60
•Fixed picasa_faces.config to rotate regions if necessary for RAW file types (thanks Stargeek)
•API Changes: ◦Added ExtendedXMP option
En de bijbehorende GUI is hier te vinden:
http://u88.n24.queensu.ca/exiftool/foru ... 750.0.html" onclick="window.open(this.href);return false;
remoss
Re: ExifTool --> 9.96
Bericht door remoss » za jun 06 2015 1:05 am
Geweldige tooltjes, gebruik ze beide al jaren :)
