The goal of this release is to provide additional camera raw support, lens profile support and address bugs that were introduced in previous releases of Lightroom.
Bug fixes, Tethered capture, new camera and lens support updates are available in both Lightroom 6 and Lightroom CC.
Adobe Camera Raw 9.1 Released
adobe-lightroom-6
Lightroom CC on the desktop
Dehaze*
Many outdoor scenes have some amount of haze due to atmospheric conditions. Dehaze is a new feature for removing/adding haze and fog from pictures.
The user can control how much haze to remove by adjusting a new slider in the Effects panel in the Dehaze section. This feature can also be used in the other direction to increase the amount of haze.
Recommended Workflow – Adjust the white balance of the image before applying the Dehaze control.
Local White and Black Adjustment Sliders*
Available with all 3 local adjustment tools: Gradient Filter, Radial Filter and Local adjustment brush
Useful for fine-tuning tonality near the brightest and darkest parts of the picture. For instance, they can be used to increase the contrast of highlights.
Recommended Workflow – Make your global adjustments first and then use the local adjustments to fine tune. Use the clip warning indicator to help avoid clipping highlights and shadows.
* Please note that these features are not available in the standalone version of Lightroom 6.1.
Lightroom on iOS:
Video support: You can now import, and sync your iPhone and iPad created videos from Lightroom on iOS to the web and desktop.
More adjustment tools
Vignettes
Adjust the Color channel and B&W mix
Tone Curve
New Camera Support in Camera Raw 9.1
Fujifilm X-T10
Nikon 1 J5
Nikon D810A
Panasonic DMC-G7
Pentax K-S2
Pentax K3 II (*)
*Preliminary support. The multi-shot Pixel Shift Resolution and HDR features are still under investigation.
New Lens Profiles in Camera Raw 9.1
Mount Name
Canon Canon EF 50mm f/1.8 STM
Canon Canon EF 400mm f/4 DO IS II USM
Canon Tokina AT-X 11-20mm f/2.8 PRO DX
DJI PHANTOM 3 FC300S (RAW + JPEG)
DJI PHANTOM 3 FC300X (RAW + JPEG)
Leica Voigtlander VM 15mm f4.5 Super Wide Heliar III Aspherical
Nikon Nikon 1 NIKKOR VR 10-100mm f/4-5.6
Nikon Nikon 1 NIKKOR VR PD-Zoom 10-100mm f/4.5-5.6
Nikon Nikon AF NIKKOR 85mm f/1.4D IF
Nikon Tokina AT-X 11-20mm f/2.8 PRO DX
Pentax HD PENTAX-DA 18-50mm f/4-5.6 DC WR RE
Pentax HD PENTAX-DA L 18-50mm f/4-5.6 DC WR RE
Pentax HD PENTAX-D FA 150-450mm f/4.5-5.6ED DC AW
Sony Alpha Sony 16-35mm f/2.8 ZA SSM II
Sony Alpha Sony 24-70mm f/2.8 ZA SSM II
Sony Alpha Sony 70-300mm f/4.5-5.6 G SSM II
Bugs Fixed:
Local adjustment brush did not properly use the pressure sensitivity information from a Wacom tablet (Windows)
Develop adjustments are lost after Edit In while auto-write XMP is turned on
Entering name with trailing space while face tagging changes case of keyword
Keyword hierarchies are not displayed when naming face regions
Keywords get erroneously renamed when using hierarchical keywords in face tagging
Keyboard shortcuts for Merge don’t work in German or French
Improved quality of display color management on some widegamut displays when Use Graphics Processor is enabled
Card reader not automatically found (Windows Autoplay registry issue)
Crash when Android device is mounted (Windows)
Closing the crop tool or cycling Full Screen modes with Lights Out mode makes entire screen go black
Cannot enter negative values in Develop in some languages
Mouse wheel changes brush size and scrolls image
Import from Photoshop Elements now allows you to include People keywords.
Reduced “color blur” artifacts when processing Fujifilm XTrans raw images – In collaboration with Fujifilm, we are still investigating methods to improve fine detail rendering and overall edge definition
If a Person keyword was NOT marked as “Include on Export”, it is still nevertheless included on export unless “Remove Person Info” is selected. Please note that this only occurred for People keywords.
The “Remove Chromatic Aberration” checkbox is now enabled by default for all Fujifilm cameras.
HDR and Pano Merge: Cleared in-camera crop before merging rather than destructively applying it prior to merging.
Pano Merge: Fixed a Pano blending issue specific to Leica M9.
Fixed a bug with Panasonic LX100 – extended ISO 100 was too bright and Magenta Highlights have been fixed.
Fixed a bug with Nikon Coolpix P7800 NRW raw files that showed only Matrix as camera profile.
Fixed crash when reading some JPEG images
When enabling “Before/After” preview in the Develop module, the screen flickered before showing the Before preview. This only occurred when GPU was enabled
Lightroom starts slowly, any attempt to do something results in the blue spinning-wheel and “Not Responding” when connect to LAN without LAN/internet connection
If a catalog is too large, the zipped backup can’t be unzipped
Export creates erroneous Invalid Constraint Size Error
Download Links
Camera Raw 9 – Please use the update mechanism in Photoshop CS6 and Creative Cloud app.
DNG Converter 9.1: Mac | PC
Photoshop Lightroom 6.1
