Nikon 16-80mm f/2.8-4E ED VR DX prijs en plaaatje
Highlander
Forumbeheerder
Forumbeheerder
Bericht door Highlander » wo jul 01 2015 10:43 am
First image and price information of the Nikon 16-80mm f/2.8-4E ED VR DX lens has been leaked on the web.
According to latest Nikon rumors, the company will hold a major product launch event by the end of this week. The announcement expected to include three new lenses. These are the 500mm f/4 FL VR, 600mm f/4 FL VR, and the 16-80mm f/2.8-4 DX lens.
One of them is the AF-S DX Nikkor 16-80mm f/2.8-4E ED VR standart zoom lens. This lens will employ fluorine and Nano Crystal coatings as well as an electromagnetic diaphragm.
Nikon AF-S DX NIKKOR 16-80mm f/2.8-4E ED VR Lens First Image
nikon-af-s-dx-nikkor-16-80mm-f2-8-4e-ed-vr-lens-first-image-leaked
Nikon AF-S DX NIKKOR 16-80mm f/2.8-4E ED VR will also come packed with built-in Vibration Reduction system, which will provide up to four stops of stabilization. See the specs list below.
AF-S DX NIKKOR 16-80mm f/2.8-4E ED VR Lens Specs
DX format
Lightweight
Electromagnetic diaphragm
ED glass
Fluorine coating
VR up to 4 stops
Japanese price: 120,000 yen, US price will probably be $900
Shipping in Japan will start on July 16, 2015
Japanese price of the lens will be around 120,000 yen. This means that the Nikon 16-80mm f/2.8-4E ED VR DX lens will cost about $900 in the US.
via Digicame-info
Chris
JvdKooij
Re: Nikon 16-80mm f/2.8-4E ED VR DX prijs en plaaatje
Bericht door JvdKooij » wo jul 01 2015 11:23 am
lekker prijsje (ga ik even uit van het systeem dat de dollarprijs meestal 1 op1 vertaald wordt naar euro's)
Jaap
Bericht door Hans Braakhuis » do jul 02 2015 7:43 am
De prijs wordt heftig: advies 1.199 euro,
Heb nog eens even naar de oude 16-85 gekeken: advies 690 euro
Quote: The new lens is supposed to be a replacement for the Nikkor 16-85mm f/3.5-5.6G DX ED VR (currently $200 off)
het Nederlandse persbericht:
Nikon kondigt vandaag een gloednieuw krachtig DX-formaat zoomobjectief aan. Het AF-S DX NIKKOR 16–80mm f/2.8–4E ED VR-objectief is voorzien van de nieuwste technologie, heeft een ongelooflijk compacte constructie en is gemaakt voor fotografen die hoge verwachtingen hebben van hun apparatuur.
Dit is het eerste DX-objectief dat is voorzien van enkele van Nikon's meest recente professionele technologieën, zoals een elektromagnetisch diafragma en een beschermende fluorcoat op de voorste lens. En het is ook het eerste DX-objectief met Nikon's alom geprezen Nano Crystal Coat wat beeldschaduwen en lichtvlekken tegengaat.
Dit geavanceerde, compacte zoomobjectief is het perfecte objectief voor op reis, want het weegt slechts 480 gram. Het grote brandpuntsbereik van 16-80 mm is geschikt voor de meeste opnamesituaties, van uitgestrekte landschappen tot portretten van dichtbij. Het heldere diafragma van f/2.8-4 biedt een merkbaar voordeel bij weinig licht en Nikon's indrukwekkende vibratiereductie van vier stops houdt beelden zelfs bij lange sluitertijden scherp.
Matthieu van Vliet, Country manager Nikon Nederland zegt hierover: “Het nieuwe, indrukwekkende objectief van 16-80 mm combineert geavanceerde NIKKOR-technologie met compromisloze gebruiksmogelijkheden en beschikt over alle benodigde eigenschappen om zich op reis onmisbaar te maken. Wat de techniek betreft profiteert dit objectief van de nieuwste objectiefinnovaties en van allang beproefde klassieke technologieën zoals Nikon's wereldberoemde Nano Crystal Coat en een krachtig vibratiereductiesysteem. Wat betreft gebruiksmogelijkheden biedt dit objectief een veelzijdige dekking van groothoek tot tele en een groot diafragma van f/2.8-4, maar is de body toch uiterst compact. Deze sterke combinatie van voordelen levert een zoomobjectief op dat u overal mee naar toe kunt nemen, niet veel ruimte in uw bagage inneemt, maar bovenal fantastische beelden vastlegt.”
De allernieuwste technologie
Een groot aantal technologieën van professionele kwaliteit waarborgt dat dit topklasse DX-zoomobjectief indrukwekkende prestaties levert. Een elektromagnetisch diafragma biedt een nauwkeurigere belichting, met name wanneer u opnamen bij hoge beeldsnelheden maakt. Nikon's beschermende fluorcoat stoot water, stof en vuil actief af zonder dat dit ten koste gaat van de beeldkwaliteit en maakt het gemakkelijker om de lens schoon te maken met minder kans op krassen. Daarbij is dit het eerste DX-objectief met Nikon's beroemde Nano Crystal Coat antireflectiecoating.
Snelle zoom
Het nieuwe NIKKOR DX f/2.8-4-objectief van 16-80 mm is een interessante nieuwe optie voor avontuurlijke fotografen. De veelzijdige 5x zoom dekt het equivalent van 24-120 mm in full-frame-formaat, terwijl het grote maximale diafragma meer opnamemogelijkheden biedt. Of u nu opnamen maakt in de groothoekstand of de telestand van het zoombereik, u kunt fraaie onscherpe achtergronden, heldere opnamen bij weinig licht en een duidelijke scheiding van voor- en achtergrond creëren. Daarbij kunt u met de kortste scherpstelafstand uw onderwerp tot op slechts 0,35 m afstand fotograferen.
Of u nu landschappen, interieurs, spontane straatopnamen of portretten van dichtbij fotografeert, met dit lichtsterke zoomobjectief kunt u waar u ook op reis bent schitterende verhalen in hoge resolutie vastleggen.
Stabiel en stil
Het AF-S DX NIKKOR 16–80mm f/2.8–4E ED VR-objectief is voorzien van de nieuwste generatie van Nikon’s indrukwekkende vibratiereductietechnologie. Hierdoor kunt u werken met sluitertijden die tot vier stops langer zijn zonder dat de door cameratrilling veroorzaakte onscherpte de fotokwaliteit aantast. Het VR-systeem heeft een stille werking en biedt twee standen (Normal voor algemene fotografie uit de hand en Active om de mechanische trillingsfrequenties te corrigeren) plus automatische statiefdetectie. Terwijl VR het beeld stabiel houdt, zorgt de compacte Silent Wave Motor (SWM) voor een snelle, stille en nauwkeurige autofocus binnen het gehele zoombereik, wat in het bijzonder goed van pas komt wanneer u films maakt. Voor kritieke momenten tijdens het scherpstellen kunt u met de M/A-schakelaar voor de scherpstelstand naadloos overschakelen naar prioriteit voor handmatige scherpstelling.
Hoge optische prestaties
Het geavanceerde optische ontwerp van dit objectief bestaat uit 17 elementen in 13 groepen en is ervoor gemaakt om hedendaagse DX-formaat D-SLR's met een hoge resolutie maximaal te laten presteren. Naast de Nano Crystal Coat en het voorste glaselement voorzien van fluorcoat bevat het objectief drie asferische lenselementen en vier elementen van ED-glas (extra lage dispersie). Beeldschaduwen, lichtvlekken en aberraties worden bij beelden met een hoog contrast bij allerlei lichtomstandigheden en binnen het gehele zoombereik tot een minimum beperkt.
Perfect in balans - reis met eersteklas comfort
Met een gewicht van slechts 480 gram biedt het NIKKOR DX f/2.8-4-objectief van 16-80 mm een uitstekende formaat-prestatieverhouding en is het perfect geschikt als objectief voor algemeen gebruik en de ideale keus voor avontuurlijke en reislustige fotografen. Het objectief past uitstekend op de camerabody en de cilinder heeft een rubberen ring die bescherming biedt tegen weersinvloeden. Dankzij de geavanceerde technologie en de compacte afmetingen voorziet dit objectief in de behoeften van kritische amateurfotografen en professionele fotografen die licht bepakt willen reizen met een DX-formaat camera.
Het objectief wordt geleverd met de HB-75 zonnekap.
Prijs en beschikbaarheid:
De AF-S DX NIKKOR 16–80mm f/2.8–4E ED VR is beschikbaar vanaf 16 juli a.s. De verkoopadviesprijs bedraagt €1199,-.
ArendV
Bericht door ArendV » do jul 02 2015 12:25 pm
Even samenvatten: ongeveer even groot en licht als de 16-85 bij ongeveer een stop lichter (2/3 stop bij 16mm en 1 stop bij 80mm) wat knap is, zelfde mimale scherpstelafstand (en vergroting), vergelijkbare MTF grafiekjes en een zeer stevige prijs (en een iets groter filter van 72mm).
Nu de eerste praktijkfoto's afwachten.
Voor wie geínteresseerd is, hier zijn links naar de MTFs van de 16-80 en de 16-85
Groeten - Arend / flickr
ArendV
Bericht door ArendV » do jul 02 2015 2:48 pm
Eerste foto's (helaas ontbreken EXIF gegevens)
http://www.cameraegg.org/af-s-dx-nikkor ... le-images/
lock
Bericht door lock » di jul 07 2015 8:18 pm
ArendV schreef:Even samenvatten: ongeveer even groot en licht als de 16-85 bij ongeveer een stop lichter (2/3 stop bij 16mm en 1 stop bij 80mm) wat knap is, zelfde mimale scherpstelafstand (en vergroting), vergelijkbare MTF grafiekjes en een zeer stevige prijs (en een iets groter filter van 72mm).
Maar de tests zijn niet met dezelfde diafragmas gedaan. Helemaal open lijkt de nieuwe lens overigens niet echt beter. Maar what's in an MTF....
Javelin
Bericht door Javelin » di jul 07 2015 8:30 pm
Waar het alleen maar om gaat: wil je dit ding of niet? :lol:
Heel veel analoog en steeds meer digitaal.
Paulus van Aken
Bericht door Paulus van Aken » wo jul 08 2015 5:52 pm
Bij de introductie indertijd van weer een 18-xxx objectief door Nikon de opmerking gemaakt dat ze eens met een 16-80 f4 zouden moeten komen.
Vind het dus heel mooi dat ze daarnaar luisteren, maar aan deze prijs ga ik m'n 16-85 echt niet inruilen....
Wel mooi.
D7000 met MB-D11, 16-85, micro Nikkor 2,8 105, 35-1.8, 70-300, 50-1.8, en Tokina 10-17 en 12-24, benevens 2 SB600
en nog F801s met glaasjes.
moerman
Bericht door moerman » wo jul 08 2015 7:37 pm
Ik zou hem graag willen hebben! Alleen niet voor deze prijs ...zou die nog eens tot 800 euro dalen?
D7100, D90, Nikon 10-24, Nikon 18-105, Nikon 2.8/70-200 VR, Tamron 2.0/60 mm macro
Bericht door Peter » wo jul 08 2015 8:53 pm
Ik vind het persoonlijk een absurde prijs.
JaapV
Bericht door JaapV » wo jul 08 2015 9:08 pm
De prijs is m.i. niet eens zo gek, vergeleken bij de al wat oudere, maar door velen aanbeden 17-55 2.8.
Wat me ook aardig lijkt is een tabelletje bij welke brandpuntsafstanden het diafragma verspringt: wat is de lichtsterkte in de praktijk.
de Sigma 17-70 (met dezelfde filtermaat) die ik een tijdje had verliep als volgt:
vanaf
  • 17mm 2.8
    19mm 3.0
    26mm 3.2
    32mm 3.3
    38mm 3.5
    46mm 3.8
    58mm 4.0
Een soortgelijk tabelletje (of grafiekje) van de Nikkor 17-55 kan daarbij ook nuttige inzichten geven.
Groet, Jaap
Bericht door Skippy » wo jul 08 2015 9:43 pm
De prijs is m.i. te hoog. Een Fuji 18-55mm f2.8-4 APS-C objectief kost € 599. Wie is bereid om voor het extra bereik (met ongetwijfeld optische compromissen) zoveel extra te betalen? Waarom niet een update van de 17-55mm f2.8 gemaakt?
Bericht door Patrick » wo jul 08 2015 9:53 pm
Voor iets meer dan dat bedrag krijg je er een X-E1 camera plus een 50-230 bij. Er zit dus dik marge in die adviesprijs....
Ivan10
Bericht door Ivan10 » wo jul 08 2015 10:05 pm
Wat een prijs, spaar dan maar door voor een 24-70 mm.
EdvandeZilver
Bericht door EdvandeZilver » wo jul 08 2015 10:18 pm
Dit biedt mooie kansen voor gebruikers van de goedkopere kit "lenzen" om te upgraden naar de nog steeds fraai presterende 16-85mm . Deze zal ongetwijfeld een prijsdump ondergaan, zie quote Hans Braakhuis.
Terug naar “Standaardzoom”
