Batterijen D5/D6/Z9
- ahhveurink
Batterijen D5/D6/Z9
Wie weet of de batterijen van de D5 en D6 ook in de Z9 kunnen worden gebruikt?
- Bas
- Ervaringsniveau: **
Re: Batterijen D5/D6/Z9
Ja.
https://www.nikonimgsupport.com/eu/BV_a ... lang=en_GB
EN-EL18, EN-EL18a, EN-EL18b, EN-EL18c and EN-EL18d Rechargeable Li-ion batteries
All five batteries are cross-compatible, the main difference between them is that the EN-EL18 battery capacity of 2000mAh was increased to 2500mAh in the EN-EL18a, b and c batteries and to 3300mAh in the EN-EL18d battery.
Due to the lower capacity of the EN-EL18 battery, when it is used in a camera designed for use with the EN-EL18a, b, c or d battery, it will result in lower than expected performance (fewer pictures can be taken with a single charge). To guarantee your camera performs as expected, please use the battery specified in the user manual.
- ahhveurink
ja hoor werkt goed.. heb hier een D6 accu in de Z9 zitten nu.
